I've got M-T6 model of the Snowman cooler
It's just about as efficient as Freezer 33 I had before...
I don't have a lab to test it perfectly.
Worth mentioning - the cooler is not as fixed as I'd like - it's only mounted using a clip, not screws:
Only with two clips to the mounting frame, at least with Intel 1151 mobo. Can't really find an image to illustrate it. Looking at the Aliexpress you'd get the idea.
Pax vobiscum
https://linustechtips.com/topic/1140416-snowman-cooler/#findComment-13175494
