Not exactly sure what you're asking here and you pictures don't exactly give a lot of information. First thing first, that bios CPU temp is not normal even if it was an offset temp sensor it doesn't seem right. Looks like you're using the Corsair pump/res combo which has a pwm pump which should be plugged into a pump header on the motherboard but for testing I would plug it into a fan header adapter pulling power directly from the psu so it will run at full speed. Iif that doesn't help temps I would double check the cpu block mount make sure proper thermal paste spread is achieved.
More links in my profile! Builds: Project(Main Rig): Cosmos Sv2 -- 2nd PC: Old School AMD -- Project: HD4890 Revival,
↓↓↓↓↓↓↓↓ Specs Below ↓↓↓↓↓↓↓↓
Cosmos Sv2:
  • CPU: Intel Core i9 9900K @ 5.1ghz
  • Motherboard: Asus PRIME Z390-A
  • RAM: Corsair Vengeance RGB Pro 32 GB (4 x 8 GB) DDR4-3000
  • GPU: Asus GeForce RTX 2080 Ti 11 GB Turbo
  • Case: Modded Cosmos S (Cosmos Sv2)
  • Storage: Samsung 970 Evo 500 GB M.2-2280 NVME, WD Black SN750 2TB NVMe, 2x WD Red 2TB raid 1, 150GB Toshiba 2.5"
  • PSU: Corsair HX850
  • Display(s): Samsung LC32JG50QQNZA 32.0" 2560x1440 144 Hz, LG 29UM58-P 29.0" 2560x1080 75 Hz
  • Cooling: Custom Loop
  • Keyboard: Corsair K95 Platinum
  • Mouse: Corsair Dark Core
  • Sound: Oboard with Logitech something or other 5.1 speakers and HyperX Headset
  • OS: Win 10 Pro
  • PC Part Picker URL: https://ca.pcpartpicker.com/user/NotSoEpicMods/saved/LYysZL
Old School AMD:
  • CPU: AMD Phenom II x6 1090T
  • Motherboard: Asus Sabertooth 990FX rev1.0
  • RAM: 16GB Patriot Sector 5
  • GPU: XFX HD 7950
  • Case: Cougar MX330-G Glass Window
  • Storage: 2x HyperX 3K 120GB SSD
  • PSU: Corsair 650W
  • Display(s): Samsung 32"
  • Cooling: Hyper 212+
  • Keyboard: Logitech G110
  • Mouse: Logitech M100
  • Sound: HyperX Headset
  • OS: Win 7 Ultimate
https://linustechtips.com/topic/1139474-cpu-problems/#findComment-13168739
Well do you know how to adjust the fan profile?
the pump is plugged into the cpu heads as it reads 4K plus rpm.
So I assume it bled without issues? Didn’t you post about something earlier?
If you were to cold boot into the bios, as in the pc wasn’t on for a long time and it got that hot, it’s a mount issue. Even with no flow, just having the block on it with fluid would keep the temps much lower than that.
So some more info could help. As in cold boot temps. Leaning towards block install issues of some kind.
https://linustechtips.com/topic/1139474-cpu-problems/#findComment-13171891
