I was preparing my arduino uno to run a program to use the dht11 module. After it compiled sucessfuly, whent trying to send the actual program to the arduino, it appeard the following error:
Arduino: 1.8.10 (Windows 7), Placa:"Arduino/Genuino Uno"
O rascunho usa 6728 bytes (20%) do espaço de armazenamento do programa. O máximo é 32256 bytes.
Variáveis globais usam 219 bytes (10%) de memória dinâmica, restando 1829 bytes para variáveis locais. O maximo é 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x20
Ocorreu um erro a enviar o rascunho
Este relatório teria mais informação com a
opção «Mostrar mensagens detalhadas durante a
compilação» seleccionada nas Preferências.
I do not have any module connected to the arduino and its connected to the computer throught a usb cable. Can any of you help me?
https://linustechtips.com/topic/1138761-arduino-help-sync-erroer-while-compiling/
From quick googling it appears this error occurs when you haven't selected correct board and port in your arduino IDE.
Go to Tools -> Board -> select Arduino Uno
then Tools -> Port -> select COM port on which the uno is connected.
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
