Hi guys :) I just overclocked my cpu and gpu for the first time, is my result any good?
I7-9700K: 5GHZ on all cors, at 1.3V and highest temp at 69 degrees. :)
Msi RTX2070 super gaming X trio: 2040 MHZ core clock and 7800 MHZ memory clock, at 60 degrees. :)
For mobo, I'm using, msi Z390 MPG gaming pro carbon :)
https://linustechtips.com/topic/1137811-my-first-overclock/
seems good, what software did you use to verify it?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1137811-my-first-overclock/#findComment-13156000
In before XTU
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1137811-my-first-overclock/#findComment-13156010
1 minute ago, Xzero905 said:
I'm using Aida64 + 3dmark + pcmark10 :)
I'd argue they are realistic enough and as long as it works with your apps, it's stable enough.
I'd probably do something more substantial like P95 if I was using it to make money, though.
https://linustechtips.com/topic/1137811-my-first-overclock/#findComment-13156035
I'm only using it to game on :) it's my first PC build ^^
https://linustechtips.com/topic/1137811-my-first-overclock/#findComment-13156039
9 minutes ago, Xzero905 said:
After som tweeking, I'm now stable at 2.8V 5GHZ whit a ring ratio at 47GHZ, and a AVX offset of 300MHZ + loadline calibration at 2 (out of 7) :)
1.28v? i hope? lol
https://linustechtips.com/topic/1137811-my-first-overclock/#findComment-13157999
Nice we have similar setup
8700k 5ghz 1.3v
and rtx 2080 none super 2040/55 MHz
16ghz on me
memory
-14900kf
- 4000 32gb ram
-4070ti super duper
https://linustechtips.com/topic/1137811-my-first-overclock/#findComment-13158382
