iBuyPower PC Cpu Cooling Issue
Hello.
Around 2 years ago, I purchased an iBuyPower PC.
It has an Nvidia Geforce Gtx 1080, Intel Core I7 7700k and 16gb of ram.
The model of the pc is: TRACE931
Under medium/high load, the cpu reaches temps up to 100C.
On idle, the cpu temp is from 60-80C.
I use a liquid cooler. I think there is something wrong with the cooler, or it just does not work. Does anyone know how I can somehow fix it? Would I need a new cooler?
I'm not good with computers and i probably have no idea what im doing.
https://linustechtips.com/topic/1137153-ibuypower-pc-cpu-cooling-issue/
To be honest you should be getting in contact with iBuyPower, they built it so they should offer you support for their product.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
7 minutes ago, SnowVolf said:
Hello.
Like @LinusTechTipsFanFromDarlo said, take it up with customer service. I heard many great words about Ibuypowers.
If that dont work, come back to us and we will help.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
You'd probably need to drain and fill the reservoir with fresh coolant as well as clean the heatsink and apply fresh thermal paste as well.
Phone 1 (Daily Driver): Samsung Galaxy Z Fold2 5G
Phone 2 (Work): Samsung Galaxy S21 Ultra 5G 256gb
Laptop 1 (Production): 16" MBP2019, i7, 5500M, 32GB DDR4, 2TB SSD
Laptop 2 (Gaming): Toshiba Qosmio X875, i7 3630QM, GTX 670M, 16GB DDR3
What are you using to stress test for temps?
Were temps always this high?
Can you feel liquid moving through the tubing when the system is on?
