Hello guys.I bought a pc case and put my components in.My gpu goes up to 78 degrees.I have an rtx 2060 zotac twin fan.Is that good for my gpu?
My system spec:
Msi MPG Z590 Gaming force
I5 11400f
Msi Rtx 2060 Gaming Z
Gigabyte aorus 2x8gb CL18 3600mhz
8x12cm fans sama rgb
Corsair CX650F Rgb
Ssd 128gb toshiba
2tb of wd green hdd
Hp omen 25 144hz 1080p
https://linustechtips.com/topic/1136998-rtx-2060-temps/
That's fine.
Anything over like 86 is worrisome. Most gpus stay between 75-84 on load
https://linustechtips.com/topic/1136998-rtx-2060-temps/#findComment-13149881
Thanks guys.I wanted to put my gpu fan on 100% but cant do it with msibafterburner.I downloaded evga precision and now its much lower temp!
My system spec:
I5 11400f
Corsair CX650F Rgb
Ssd 128gb toshiba
2tb of wd green hdd
https://linustechtips.com/topic/1136998-rtx-2060-temps/#findComment-13150979
