Hello all, does anyone has any clue on how to pick a Lan Card, my onboard z97 gaming 9 ack ethernet which is the Killer E2200 ethernet controller seems to be having issues due to it randomly disconnecting. I checked if its the wall socket issue or my ISP using a switch but it wasn't. So here I am trying to find a new Lan Card but i have no idea what to pick.
https://linustechtips.com/topic/1134631-picking-lan-card-how/
If its just for a general purpose/gaming PC running Windows then just whatever is gigabit in your budget and available in your area.
TP-Link & Netgear are generally quite cheap and widely available.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/1134631-picking-lan-card-how/#findComment-13130483
Adding to Jarsky's statement Intel makes well regarded 1Gbit NICs as well. Any modern one should work fine for general purpose applications. Windows will likely have a pre-installed driver for it as well.
https://linustechtips.com/topic/1134631-picking-lan-card-how/#findComment-13131580
