Hey all, I have been into streaming for quite some time. I'm familiar with all of the settings and how everything works. But, when I built my pc, things were never right for me. I feel an input lag when I'm streaming through obs.
Specs:
Cpu- Intel I9-9900k
GPU- evga 2080ti ftw ultra
Ram- 32 gb trident z rgb @3200
Motherboard- asus maximus xi hero wifi
Storage- 2 tb Seagate Hdd, 1 tb Samsung ssd's, 520 gb Samsung evo m.2
I have this insane build, and I figure I should be able to stream okay. I'm not over doing the settings in obs, I'm just doing 3000 bitrate at 30 fps. Scaled to 720p as well. So I'm confused. Can anyone help?
https://linustechtips.com/topic/1134460-streaming-on-obs-causing-input-lag/
Are you using display capture or game capture? IIRC display capture forces vsync which will cause input lag.
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
Well, I was using display capture. I'll check out the game capture in like 10 minutes when I try again!
Just now, SonManic said:
I have 100 MB download speed and about 12 up. It's the standard from spectrum.
Alright! But the actual router make and model you use, do you know it?
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
