Hello, I have a ptoblem that is hard to describe, but I'll try my best...
So, I got my new PC and the cooler is kinda loud, when used over 50%. It makes humming sound. Also, while on idle pc reached 50-60°C, on load under 80°C. But the most annoying thing is when I launch a game and play for a while, pc start vibrating (in some kind of patern). It happens randomly and after few minutes stops, then after a while repeats. Do you have any ideas, what could be wrong?
PC Specs:
Ryzen 5 2600 with stock cooler
Asrocj b450m pro4 mb
Asus GTX 1660s dual evo oc
16gb 3200mhz hyperx fury ram
Silentiumpc supremo l2 650w psu
Antec dp301m case
https://linustechtips.com/topic/1134402-pc-vibrates-on-load/
Vibrating like resonating ? Your case metal panels are too thin or there's too much plastic. Or maybe you didn't screw everything in place tightly (don't overtight too tho) or not all motherboard standoffs were installed. Another possibility is that it's coil whine, then it comes from motherboard\GPU VRM or PSU. Only you can pin down the source.
Tag or quote me so i see your reply
https://linustechtips.com/topic/1134402-pc-vibrates-on-load/#findComment-13128697
