Help With Case
Go to solution Solved by Whiro,
Cheap cases usually lack in airflow department etc.
https://pcpartpicker.com/product/rnGxFT/cooler-master-masterbox-q300l-microatx-mini-tower-case-mcb-q300l-kann-s00
You can try this case but try to read some reviews cos I’m not 100% sure about airflow
New to building Pcs and i think i have just feel in to my first trap i picked up a ASRock MicroATX Motherboard (B450M PRO4) for my build and decided on a Thermaltake H13 Versa Mini Tower micro-ATX Windowed PC Gaming Case now when building is impossible to cable managed and case is really to small for the motherboard it fits in it but cant get any good management for cables and couldn't properly mound SSDs in there proper place, dose anyone have any case recommendations for this motherboard, the cheaper the better (£/$30-40)
Would be greatly appreciated cheers !
https://linustechtips.com/topic/1134192-help-with-case/
if money is an issue, just place it on the mobo box and save up a bit more. I've seen it before and it works better than the cheapest $50 cases
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
https://linustechtips.com/topic/1134192-help-with-case/#findComment-13127284
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1134192-help-with-case/#findComment-13127444
