CPU Overheating
Solved by Mister Woof,
If it's the Intel stock cooler, it can be tricky to reinstall and it sounds like bad mounting pressure.
The oem Intel heat sink has clips and a center punch pin thing. Make sure the clip is in first before you try to depression the center pin
I feel as if I'm describing this poorly but if anyone has a better way of explaining lol
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
