my overclock failed help
Solved by Jurrunio,
1 minute ago, dreamcast4599 said:do i want more drop or less drop also how do i test it sorry still kinda new to all this
21 minutes ago, Jurrunio said:You find the settings that gives you the least voltage drop from idle to full load (definitely not settings that give overshoot), then go one step down (so voltage drop is slightly more).
