In terms of the GPU, the 7790 is very well priced for its performance. You might want to check this review out, http://www.tomshardware.com/reviews/radeon-hd-7790-bonaire-performance,3462-11.html it just compares the cad to a number of other similarly priced cards. If you have a bit of extra money to spend on the budget you might want to consider the 7850.
In terms of the cpu I wont comment because I'm really  not familiar with the AMD cpus. However bf3 isn't tooo cpu intensive so I'm sure it would be fine.
https://linustechtips.com/topic/11338-first-pc-build-suggestions/#findComment-120955
I am not sure about Battle field never played it, as far as your build looks like a all around good imo budget gaming computer.
if i changed anything about it i would either change the gpu to a 6670 http://www.newegg.com/Product/Product.aspx?Item=N82E16814150587  to set up Dual Graphics "crossfire" with your APU or
i would change the the cpu/mobo since you have a discrete gpu selected all ready, my suggestion for that would be
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130620 for MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113287 for CPU
cost about the same as the FM2 Motherboard and APU you had selected all ready and has little more kick then the A10 in my experience, also overclocks a little better too again in my experience.
In all honestly you could just keep the APU and try to get a bigger gpu like what Preston suggested.
https://linustechtips.com/topic/11338-first-pc-build-suggestions/#findComment-120991
