Looking for a budget monitor for my new budget gaming rig. Freesync, high fps as possible and colour accurate, at least 90% srgb is what I'm looking for. I'm down to these two choices;
25 inch LG Ultrawide
https://www.amazon.co.uk/gp/aw/d/B01BV1XB2K/ref=ox_sc_saved_image_2?smid=A3P5ROKL5A1OLE&psc=1
electriQ 25" monitor
https://www.laptopsdirect.ie/electriq-25-full-hd-hdr-165hz-freesync-usb-c-gaming-monitor-eiq-25fhdo165fsguc/version.asp
Anyone familiar with these screens? What range does their freesync implementation work at? Are they colour accurate? Any advice would be appreciated, not that much info available for them online.
Feel free to suggest another >60hz budget IPS with freesync too. Buying from the UK.
https://linustechtips.com/topic/1132390-monitor-advice-needed/
A monitor in our days must be at least HDR (10) IPS, i am not a fan of freesync/Gsync.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1132390-monitor-advice-needed/#findComment-13111855
Why do you not like free sync/gsync?
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1132390-monitor-advice-needed/#findComment-13111861
 Maybe because i use 2 monitors, one main 4k and one 1080p and it cause me problems.
I am very well covered with uncaps FPS setting and Vsync in most games except FPS
https://linustechtips.com/topic/1132390-monitor-advice-needed/#findComment-13111870
HDR on PC is absolute BS at the moment, and I'm looking for a ***budget*** monitor. Also Freesync is mandatory, not HDR. For a TV, sure.
https://linustechtips.com/topic/1132390-monitor-advice-needed/#findComment-13112335
