RTX 2080Ti Benchmark, help
Solved by Envit0,
9 hours ago, Ruivo said:I've tried some benchmarks on the 'Kombustor' from MSI, but they are not "so good" because the are not well developed and are not made for "heavy benchmarks", all of them my GPU can easily handle. I'm thinkin about getting Cinabench or Blender Render, these two are used by a lot people, altough, for me, the best benchmark you can get is the 3D Mark TimeSpy so I'm thinking in buying it, it is around 2$
The two mentioned are used for CPU's, don't really hear them being used for GPU benchmark. (Cinabench at least). Suggest 3D Mark, they have a dx12 free version of timespy. Run that + some benchmarks in-game and compare to those e.g. posted on youtube. This will give a good info for you to compare
