3 minutes ago, BOSSAVENG said:
low budget mobo
Low budget and R7 3800X don't mix I'm afraid, if you can afford a CPU like that then you can certainly afford a decent board.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
7 minutes ago, BOSSAVENG said:
I am building a streaming setup so I wanna go for amd Ryzen7 3800x and 2060 super but I cant decide what motherboard I can go for and I want a low budget mobo so please help for a cheap mobo for 3rd gen Ryzen and 2060 super
The 3800X is a waste of money unless you are getting it for the same price as the 3700X ?
Have a look at MSI B450 MAX boards. The B450-A Pro MAX is usually quite cheap.
Also an RX 5700 might be cheaper than a 2060 Super.
Ryzen 5 3600 an a 2070 super does well, and you can use nvenc to stream from GeForce experience
Primary PC:
PSU tier list
How many watts do I need?
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
