1. Budget and Location
Additional budget: up to $500, but looking to keep it as value as I can. Got my GPU + PSU @ $599 US (inc. shipping and import fees).
2. Aim
1440p high Hz gaming
3. Monitors
Planning to get a LG-32GK650F, 1440p144Hz. Will figure that out later.
4. Peripherals
Don't need peripherals included, have mouse. Will get keyboard once build is done.
5. New build for my first full fledged experience in the PC Master Race
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($114.99 @ Amazon)
Motherboard: MSI B450M PRO-VDH PLUS Micro ATX AM4 Motherboard  ($82.99 @ SuperBiiz)
Memory: Team T-Force Delta RGB 16 GB (2 x 8 GB) DDR4-3000 Memory  ($56.99 @ Newegg)
Storage: ADATA Ultimate SU800 512 GB 2.5" Solid State Drive  ($57.99 @ Amazon)
Video Card: Inno3D GeForce RTX 2070 SUPER 8 GB Twin X2 OC Video Card  (Purchased For $0.00)
Power Supply: Xilence Performance A+ 530 W 80+ Bronze Certified ATX Power Supply  (Purchased For $0.00)
Total: $312.96
Generated by PCPartPicker 2019-11-29 08:26 EST-0500
Case will probably be Armaggeddon Nimitz N5, that should be flexible since my graphics card is 268mm, can fit most cases. Feel free to ask for any needed information!
https://linustechtips.com/topic/1128999-first-build-any-help/
Do you not need a case? And that PSU sketches me out.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1128999-first-build-any-help/#findComment-13086968
