Can anyone sum up those information to get a result for me please? Here is the approx configuration about both.
         Aw.             Cyber power
price 1058.           1049
gpu.   5700xt.        5700xt ( both are original one)
psu.    850w aw.    650w gold
cpu.    I7-9700.       3700x
Motherboard
 Intel® Z370 Express Chipset And assrock B 550
memory 16gb 2633 MHz.  16Gb 3000mhz
just for gaming
like league of legends apex and pubg
 I already got the cyber power one, but most people told me to go for alienware
should I return the cyber power to get Alienware?
https://linustechtips.com/topic/1128884-alienware-or-cyber-power/
ciberpower in paper is better but, better hard disk....
alienware.
-alienware is alienware , pretty,
-warranty, support, quality of material could be better in alienware.
-possibly a overall better expirience.
prebuild
- it has an ass rock
-better hd
its up to you, i feel alienware much better expirience for gaming quality of materials.
If you are looking for a boutique PC company I would recommend AVADirect. They have many components to choose from and if there is a specific part you want contact their sales and they will get it for you. They will build and test your PC for you too.
https://www.avadirect.com/
  • My system specs
  • View 91 Tempered Glass RGB Edition, No PSU, XL-ATX, Black, Full Tower Case
  • ROG MAXIMUS XI EXTREME, Intel Z390 Chipset, LGA 1151, HDMI, E-ATX Motherboard
  • Core™ i9-9900K 8-Core 3.6 - 5.0GHz Turbo, LGA 1151, 95W TDP, Processor
  • GeForce RTX™ 2080 Ti OC ROG-STRIX-RTX2080TI-O11G-GAMING, 1350 - 1665MHz, 11GB GDDR6, Graphics Card
  • ROG RYUJIN 360, 360mm Radiator, Liquid Cooling System
  • 32GB Kit (2 x 16GB) Trident Z DDR4 3200MHz, CL14, Silver-Red DIMM Memory
  • AX1600i Digital, 80 PLUS Titanium 1600W, Fanless Mode, Fully Modular, ATX Power Supply
  • Formula 7, 4g, 8.3 (W/m-K), Nano Diamond, Thermal Compound
  • On AIO cooler 6 x NF-F12 IPPC 3000 PWM 120x120x25mm 4Pin Fibre-glass SSO2 Heptaperf Retail
  • 6 x NF-A14 IPPC-3000 PWM 140mm, 3000 RPM, 158.5 CFM, 41.3 dBA, Cooling Fan
  • 1TB 970 PRO 2280, 3500 / 2700 MB/s, V-NAND 2-bit MLC, PCIe 3.0 x4 NVMe, M.2 SSD
  • Windows 10 Pro 64-bit
  • Beyerdynamic MMX 300 (2nd Generation) Premium Gaming Headset
  • ROG PG279Q
  • Corsair K95 Platinum XT
  • ROG Sica
