Help picking a RAM
Solved by karsnoordhuis,
its a dual channel kit you need. so either two or four sticks of unbuffered/ unregisterd dd3 max 1600mhz and max 32gb in total. it can be either ecc or non ecc. id go for ecc memory as you can get is super cheap on ebay. just get the maximum your budget supports. if you want the 32gb its 4x8gb.
Airmack ·
Posted in Graphics Cards0 -
Kyle89 ·
Posted in Troubleshooting2 -
5
5
ken43 ·
Posted in Troubleshooting5 -
8
thedood2k ·
Posted in Power Supplies3 -
2
DARTHDIVIDER0213 ·
Posted in Troubleshooting8
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
