15 minutes ago, Joyson96 said:
what is the real problem
Are you using the Nvidia encoder for streaming? If I'm not mistaken, PUBG is a CPU intensive game, and if you are using the x264 encoder, that could be cutting into the resources for processing game information. It could also see issues if you are using 'Game Capture' versus 'Window Capture' in some instances (or vice versa).
CPU: Intel i7 6850K
GPU: nVidia GTX 1080Ti (ZoTaC AMP! Extreme)
Motherboard: Gigabyte X99-UltraGaming
RAM: 16GB (2x 8GB) 3000Mhz EVGA SuperSC DDR4
Case: RaidMax Delta I
PSU: ThermalTake DPS-G 750W 80+ Gold
Monitor: Samsung 32" UJ590 UHD
Keyboard: Corsair K70
Mouse: Corsair Scimitar
Audio: Logitech Z200 (desktop); Roland RH-300 (headphones)
https://linustechtips.com/topic/1127722-fps-issue/#findComment-13078051
