20 hours ago, digitaldoughnut said:
If you mean from an internal USB header to a Type "A" Connector then yes, there is an NZXT internal USB hub which offers 2 type A connectors or you can buy an adapter from ebay as seen in the image below.
Thanks, that's exactly what I was looking for
https://linustechtips.com/topic/1127596-usb-adapter-for-mobo/#findComment-13079940
