Irregular noise inside PC
Solved by Dougarooo,
16 hours ago, Sundance said:I have localized the issue! Before I just unplugged the fans but I unplugged the SATA cable for the cpu cooler as a whole and the noise went away. Is there an exhaust fan on the radiator? The sound is definitely coming from there.
I'm sorry you unplugged the SATA cable for the cpu cooler...?
You said you don't have a water cooling system. I'm talking about AIOs as well. Looks like this
They come in different shapes and sizes and have tubes coming from the thing that covers the CPU.
What you just described, a SATA cable, usually connects to a AIO water cooler much like the one I linked. Air coolers just have the fan attached to a piece of metal and has a normal fan connector on the end of the cable.
