Fitted my Ryzen 5 3600 a few weeks ago, took about 1 hour.
I ran into one difficulty though, the backplate would keep falling off each time I turned my pc over to screw the heatsink in. So had to use some celotape to keep it in place temporarily until the heatsink was in.
Has anybody else had difficulties with back plates ? Thanks
https://linustechtips.com/topic/1127111-changing-cpu-difficulties/
I personally will take and hang the board half on and half off something such as a table or box so I can have one hand on the backplate, and the other lining up and tightening down the cooler up top until its secure enough I can set it back normal.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Good idea !
