I was looking to Overclock my PC but I don't have any experience with doing so. Any help would be great!
Computer Specs
• CPU: Intel Core i9-9900K
• CPU Cooler: NZXT x52 AIO
• Motherboard: Asus ROG MAXIMUS XI CODE
• Memory: G.Skill Trident Z RGB 16 GB DDR4-3200
• Harddrive Main: 2x Samsung 970 Evo 1 TB M.2-2280 NVME Raid 0
• Hardrive Secondary: Samsung 860 Evo 2 TB
• Graphics Card: ASUS ROG STRIX GeForce GTX 1080 TI 11GB OC Edition
• Case: Cooler Master MasterCase H500M
• PSU: EVGA SuperNOVA GS 650W 80+ Gold
https://linustechtips.com/topic/1126911-newbie-overclock-help/
If you really want to push the overclock you need to learn what all of the related settings in your mobo do.
If you want just a basic overclock, turn on all core sync and adjust the multiplayer (generally 50 =5ghz). Don’t get caught up in pushing your multiplayer too high, the difference between 4.8ghz and 5.0 ghz is pretty minor.
Then if your cpu is getting too hot try doing a negative voltage offset starting aroun -.005. I’m using a -.02 offset on my 9700k to keep the temps in the 60s-70s, but every cpu is different.
https://linustechtips.com/topic/1126911-newbie-overclock-help/#findComment-13071998
Thanks for the insight, I'll look into it.
https://linustechtips.com/topic/1126911-newbie-overclock-help/#findComment-13074980
Are you planning on overclocking your graphics card?
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1126911-newbie-overclock-help/#findComment-13075578
9 hours ago, Kryptos said:
Idk, what are your observations/recommendations?
What is your GPU load temperature (what's the temperature when playing a game for at least ten minutes)?
https://linustechtips.com/topic/1126911-newbie-overclock-help/#findComment-13078580
