Ok, im getting some errors on partpicker, i dont know what they mean? https://pcpartpicker.com/list/Z9pwzN
Note:The motherboard M.2 slot #1 shares bandwidth with SATA 6.0 Gb/s ports. When the M.2 slot is populated, two SATA 6.0 Gb/s ports are disabled.
Note:Some physical dimension restrictions cannot (yet) be automatically checked, such as cpu cooler / RAM clearance with modules using tall heat spreaders.
Please help!
https://linustechtips.com/topic/1126469-help/
Please help!
first note: when you use a M.2 slot.. some of the actual sata ports are disabled, If you don't use the m.2 slot then you'll have full access to them. Most people don't use all sata ports anyways.
second note: That is just telling you that it can not tell you for sure that you're going to have ram clearance with the case fans with a radiator up top.  ... look into the motherboard / case for dimensions and see if your ram will fit.
https://linustechtips.com/topic/1126469-help/#findComment-13068813
6 hours ago, HarveyBustin12 said:
i dont know anything about dimensions or shit where to find them :/
you'll be fine, stock cooler on the 2600 doesn't block any ram slots. which country are you in?
https://linustechtips.com/topic/1126469-help/#findComment-13069687
8 minutes ago, HarveyBustin12 said:
Is the US a country?
no... it's a continent, of course.
https://linustechtips.com/topic/1126469-help/#findComment-13069749
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($102.00)
Motherboard: ASRock B450M/AC Micro ATX AM4 Motherboard  ($74.99 @ Newegg) much better than the one you picked.
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 Memory  ($54.99 @ Newegg)
Storage: Team MP34 512 GB M.2-2280 NVME Solid State Drive  ($58.99 @ Amazon)
Storage: Western Digital RE 2 TB 3.5" 7200RPM Internal Hard Drive  ($43.63 @ Amazon)
Video Card: XFX Radeon RX 5700 8 GB DD Ultra Video Card  ($329.99 @ Amazon) performs better than the 2060.
Case: Deepcool MATREXX 50 ATX Mid Tower Case  ($41.99 @ Amazon)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($44.99 @ Newegg) much better quality.
Total: $751.57
Generated by PCPartPicker 2019-11-22 23:15 EST-0500
https://linustechtips.com/topic/1126469-help/#findComment-13069759
