Case Fan advice
Solved by Jurrunio,
42 minutes ago, sithuhlaing said:I'm wondering if i should add any additional fans to the case.
my recommendation is to at least use 3 fans (2 intake 1 exhaust), preferably as many fans as the case would hold
43 minutes ago, sithuhlaing said:If I should add, which fan config would be best in your opinion?
With an R5 3600 there's no need to go bigger than a Hyper 212 Black for overclocking (safe voltage is 1.35V if you ask me), but of course I wont reject big blocks of heatsink if they dont cost much more
44 minutes ago, sithuhlaing said:I've ordered most of the main components.
Which of them? the PSU is a fire hazard so I hope you didnt buy it
