Separate PSU cables for Graphics card?
Go to solution Solved by Squanchy,
2 minutes ago, Lukiepookie77 said:
So I have a Rtx 2070 super which has an 8 pin and a 6 pin connection.
I have a corsair rmx 750 gold. And the Pcie cable that goes from the PSU to GPU has an 8 pin and a 6+2 coming from the same cable.
So I can plug in to the GPU with one cable.
Should I instead use an 8 pin cable and a separate 6 pin cable? (2 cables)
Either way works, With the 6+2, you can just not use the +2 on the cable and just tuck it away, OR you can use two separate cables to have a cleaner look. Either way.
https://linustechtips.com/topic/1125856-separate-psu-cables-for-graphics-card/
From what I understand, it's best to use separate cables. I can tell you that with my Radeon VII, I don't use separate cables and when under full load, my system hard resets itself (I should really change that come to think of it).
