Hello All,
I am Planning to upgrade my current PC to bring it in line with todays upper enthusiast level PC's. I currently use my pc mostly for gaming and streaming however I have noticed that playing more modern games and streaming at the same time has become harder and my streams have been getting choppy and less smooth.
The current parts that I am looking at replacing come black friday/cyber monday are the CPU/Motherboard/Ram or the graphics card. Im currently running an i7 - 4770k with ddr3 Memory on a MSi board and I have a MSI gaming 6 980Ti. I was looking at the r9 3900k from amd as my upgrade for the CPU and a board and possibly 32 GB of ram instead of 16 GB. I just wanted to make sure that I could hold off on a graphics card update and that the CPU/Motherboard/Ram combo would be a better value to increase my stream quality?
Thanks!
https://linustechtips.com/topic/1125290-upgrade-help/
What Country do you live in and what's your budget?
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1125290-upgrade-help/#findComment-13058816
8 minutes ago, TrippyPanda said:
My Apologies, I dont need the Graphics card at the moment I was just asking if the CPU/Motherboard/ and Ram Combo would be a better upgrade currently than the graphics card for the purposes of streaming
Yes, the CPU is largely what streaming software relies on and would be the best upgrade for streaming (in which case) I wouldn't recommend more than 8 Cores for simply gaming & streaming, as you start to lose gaming performance at 10 cores and above, as it stop scaling properly beyond 8. RAM is also not a complication at 16GB as anything more is only suggested for intensive applications in 3D and or video production.
For an upper enthusiast level PC in 2019, I personally would recommend a 3700X, MSI MPG X570 EDGE, and 16GB Ripjaws X DDR4-3600
https://linustechtips.com/topic/1125290-upgrade-help/#findComment-13059040
