New to the site, I have not built a PC for a long time so just want some help making sure this is compatible plus the best possible rig for the money.
Budget £1300ish
I need everything aside from a keyboard
Use: Mainly gaming, office work and light family photo / video editing
Features: Would like it to be as quiet and small as possible, I don’t care for RBG or anything flashy.
Types of games: Broad mix; Civ, RDR2, Minecraft, will probably get Game Pass
Current rig: my imagination
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  (£174.78 @ Aria PC)
CPU Cooler: Cooler Master     MasterLiquid Lite 240 66.7 CFM Liquid CPU Cooler  (£37.38 @ Amazon UK)
Motherboard: Gigabyte X570 I AORUS PRO WIFI Mini ITX AM4 Motherboard  (£204.97 @ Laptops Direct)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 Memory  (£79.99 @ Overclockers.co.uk)
Storage: Western Digital Blue 1 TB M.2-2280 Solid State Drive  (£89.27 @ Amazon UK)
Video Card: Gigabyte GeForce RTX 2060 6 GB WINDFORCE OC Video Card  (£305.92 @ More Computers)
Case: Fractal Design Define Nano S Mini ITX Desktop Case  (£54.97 @ Laptops Direct)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  (£63.97 @ Amazon UK)
Operating System: Microsoft Windows 10 Home OEM 64-bit  (£83.00 @ Amazon UK)
Monitor: Asus VG278Q 27.0" 1920x1080 144 Hz Monitor  (£229.97 @ Laptops Direct)
Mouse: Cooler Master MM830 Wired Optical Mouse  (£55.38 @ Amazon UK)
Total: £1379.60
Generated by PCPartPicker 2019-11-19 11:53 GMT+0000
Any help and advice is hugely appreciated.
https://linustechtips.com/topic/1125211-compatibility-advice/
Hello,
You can get W10 key from ebay or amazon for 10£.
If you plan to OC, you can grab the Dark Rock 4 instead. Better SSD (performance and endurance), better GPU :)
The motherboard is Zen 2 ready and also have Wi-Fi.
https://linustechtips.com/topic/1125211-compatibility-advice/#findComment-13058159
On 11/19/2019 at 5:54 PM, Plouffe said:
Hello,
This is a nice build. Although, i don't think anyone needs to OC lower end Ryzen SKUs as they dont provide much OC headroom and already run at almost peak performance.
Aditya K. Arun / redscape photo and video.
Photography, Tech enthusiast.
500px.com/redscape_
Instagram: redscape_
https://linustechtips.com/topic/1125211-compatibility-advice/#findComment-13061378
