Hey guys. So i Have this problem, see everytime i press the on button on my computer, it immeditaly shuts off. But then the second time i press it turns on, what could cause this? Is it the front panel connectors?
-thanks
CPU: FX-8350, GPU: xfx radeon r9 290, RAM: corsair venegance 8gb, STORAGE; seagate barracuda 1TB hdd, SSDnow kingston 120gb, CPU COOLER: CM hyper 212 , CASE: fractal design XL, PSU: corsair CS 650w 80+ gold MOBO: Gigabyte GA-990FXA-UD3
https://linustechtips.com/topic/112519-pc-not-booting-correctly/
If you have your cpu overclocked i know that many corsair psu's will do a self test right on start up. It may sound like it is turning on for a few seconds then shutting off. But after 5-10 seconds after it turns back off it should turn back on. I have the same psu and mobo and a fx-8320 and it does it everytime i start mine up. Its normal. Have you ever just hit the button once and left it?
AMD diehard & Nvidia Enthusiest
https://linustechtips.com/topic/112519-pc-not-booting-correctly/#findComment-1505597
-thanks
Don't press the ON/OFF button when the system is on.
https://linustechtips.com/topic/112519-pc-not-booting-correctly/#findComment-1507283
-thanks
You can change how case buttons work from windows power settings. While in BIOS/POST screen it will shutdown PC immediedly anyway.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/112519-pc-not-booting-correctly/#findComment-1507350
