So earlier today I got a prompt to update bios so I thought sure let that go whilst I'm working. However I totally forgot and restarted my pc (file.explorer kept freezing), now my pc won't post.
 Specs:
-i5 9600k
-gigabyte z370 board
-16gb ddr4 Corsair ram
-gtx 970
-seasonic 80+ bronze PSU
I have already tried resetting cmos with no luck.
Any suggestions appreciated. Thanks.
https://linustechtips.com/topic/1124192-pc-wont-post/
22 minutes ago, abdul94 said:
gigabyte z370 board
Some board, and I know Gigabyte ones have a dual bios setting, where you can restore from a backup copy, should the main one go bad. I'd check either the manual or the online manual, and see if your board has such a feature
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1124192-pc-wont-post/#findComment-13050439
It does not it's the z370p d3, i should have mentioned in my post.
If it did it would automatically boot with the back up I believe.
https://linustechtips.com/topic/1124192-pc-wont-post/#findComment-13050454
You mentioned to tried resetting the CMOS, did you just pull the battery, or did you short the jumper as well?
https://linustechtips.com/topic/1124192-pc-wont-post/#findComment-13053448
Sorry for the super delay, i tried both. Its now gone back to the manufacturer sure the board is dead. RIP
https://linustechtips.com/topic/1124192-pc-wont-post/#findComment-13065601
