Hi i need help (question)
Solved by yaniv382,
15 minutes ago, Eigenvektor said:Pretty sure your memory controller will run both sticks at the lowest common speed (i.e. 2133 MHz), no matter if you try to run them in dual-channel configuration or not. It won't be able to run at two different speeds at the same time. So I would try dual-channel, because this way you at least get some additional bandwidth (not guaranteed to work, so probably will have to put them in different colored slots).
@Eigenvektor @C2dan88 Thank you for your replies, i will deffinatly try dual channel as first to squeeze as much performance as i can get and if it wont work then i will seperate them
i appreciate your help guys
