Airflow question
Go to solution Solved by Jurrunio,
7 minutes ago, Jameskojiro said:
my question is should the top fan be exhausting air?
Preferably, top facing panels are more prone to sucking in dust if the dust filter isnt that good.
Hi guys, I have a question regarding the best way to face my fans to maintain positive air flow as I've noticed a bit of dust gathering in a short amount of time.
First off, my camera's a total potato, so sorry for the image quality. Let me explain what the pictures cannot.
- Coolermaster h500 case
- x3 200mm Coolermaster fans (on the front and top)
- x1 CLC coolermaster 120mm AIO attached to the rear exhaust with push-pull config (x2 fans)
- Gigabyte Windforce OC 2060 Super (x3 fans)
With all that out of the way, my question is should the top fan be exhausting air?
20191115_181152.thumb.jpg.4a96780c2c7eeb3cdc1a1dcd7c631aaf.jpg20191115_181050.thumb.jpg.94d984a2ee14f54dd5a4a65579eb998b.jpg
https://linustechtips.com/topic/1124017-airflow-question/
Desktop benching:
https://linustechtips.com/topic/1124017-airflow-question/#findComment-13049388
