Good Power Supply ??
Go to solution Solved by OrionFOTL,
Hi there.
Your entire PC with i5-8400 and RTX2060 Super will only consume around 250W under heavy load, so you don't need a 650W PSU.
RTX2060 Super itself only consumes around 180W under load.
nJoy Wooden has a fake 80+ rating and wasn't tested by anybody, so we have no idea if it's garbage or good.
Pure Power 11 is good, while Corsair VS650 is low quality.
To properly help you choose a PSU, we need to know the particular web stores you're buying from. We can't just blindly start suggesting power supplies from  USA market, because you're from a different country with different options and prices.
Hi there , Im kinda new in building a gaming pc so i need your help...
I have an i5 8400 with 16gb ram and Im looking to buy a RTX 2060 SUPER. So basically i kinda need a power supply that has about 600 - 650W I think if im not wrong....
Now i have a few options but im not kinda sure in which power supply should i take.
1. nJoy Woden 650 - [ 650W , 80plus gold] - 65 Euros (about 70 dollars)
2. Be quiet! Pure Power 11 - [ 600W , 80plus gold] - 88 Euros (about 100 dollars)
3. Corsair VS650 - [ 650W , 80plus white] - 88 Euros (about 100 dollars)
If you have any other power supply that is actually better than the ones i wrote with about the same price please inform me , but if anything which one of these power supplies do i consider for my build ?
Thank you
https://linustechtips.com/topic/1123978-good-power-supply/
500w Pure Power 11, Bitfenix Whisper M 550w should be around 90€ range too
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
https://linustechtips.com/topic/1123978-good-power-supply/#findComment-13049104
I suggest you check out the PSU tier list.
Altrough the Be quiet! is a good option.
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1123978-good-power-supply/#findComment-13049108
2 minutes ago, Wolly9102 said:
I suggeat you check out the PSU tier list.
Thank you for the tier list , I searched for something like this. So Basically the Be Quiet power supply that I have in option could do the job ? Thank you
https://linustechtips.com/topic/1123978-good-power-supply/#findComment-13049113
Hi there.
https://linustechtips.com/topic/1123978-good-power-supply/#findComment-13049123
6 minutes ago, OrionFOTL said:
Hi there.
Hi , Thanks for taking the time to help me out.
So im more into the Be Quiet Power supply , here's the link where im trying to buy it from : [ https://gjirafa50.com/pjese-per-kompjutere/burime/600w-e-me-shume/burim-energjie-be-quiet!-pure-power-11-600w/ ] in this store is also the nJoy Power supply but I got the Corsair one from another Website.
So this Be quiet power supply is 600W which I think its kinda better for long term ?? because i think in the near future im going to modificate my pc more.
Thank you again.
https://linustechtips.com/topic/1123978-good-power-supply/#findComment-13049134
@Darewill
Wait? a 2060Super system consumes up to 333watts during stress (measured at wall socket, therefore, actually ~10% less than that.), WITH a 9900k CPU OC-d to all-core 5.0Ghz. You'd be fine even with a decent 450watt PSU!
Life is really challenging. I don't always suceed: )
https://linustechtips.com/topic/1123978-good-power-supply/#findComment-13049200
There are many more options. But from the PSU's you listed the Be quiet is the best one.
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1123978-good-power-supply/#findComment-13049312
10 hours ago, Darewill said:
Alright , thank all of you. You helped me a lot , thanks again and take care :)
That's the purpose of the Board. Do You have access to Bitfenix formula Gold?  Either 450 or 550w would be great. Better unit, than the PurePower 11. And cheaper.
https://linustechtips.com/topic/1123978-good-power-supply/#findComment-13050080
I looked up and searched the stores that are close to me and unfortunately I couldn’t find this power supply , apparently they don’t sell them. Anyways thanks
https://linustechtips.com/topic/1123978-good-power-supply/#findComment-13050241
