Okay so here goes, I built this after my MSI GT780R notebook died in December hence the $1300 budget.
I was looking for a good all around PC i don't just game on it until this build all i ever played was Skyrim and EVE.
Here is what I came up with
Case: Cooler Master HAF 922 Black inside and  USB 3.0
Mobo: Asus M5A99FX Pro 2.0
CPU: AMD 8320 @ 4.4 Ghz <-- couldn't get anymore out of it.
Ram: 16 Gb 1600mhz G.Skill Ripjawz
SSD: samsung 840 evo 120gb
HDD: Seagate Barracuda 1tb
Cooling: Cooler Master Seidon 240m
Graphics: Gigabyte R9 270x 4Gb OC
Psu: Cooler Master GX650
Operating System: Windows 7 64bit
Here is my current build, I plan on upgrading when i can to include 2x R9 280x's or 290x's and a ROG mobo and a Custom loop i'm not happy with my Seidon 240m temps
would also like to note i only game in 1080p for now
https://linustechtips.com/topic/112306-first-build/
beep
no offence but because this is your first build please dont go charging in trying to do a million things and making a custom loop allot of things can go wrong from a lack of experience so please im begging you here dont make a loop till you have some more experience
Specs
https://linustechtips.com/topic/112306-first-build/#findComment-1501591
get a 2gb 270 instead since you are planning to upgrade anyway.
Edit: $1300 USD? That is enough for a 780 and an i5
Please read carefully, he has already built his first pc, this is an upgrade build log (I'm guessing).
And it's actually a pretty nice all purpose build.
THE signature
https://linustechtips.com/topic/112306-first-build/#findComment-1501605
Overkill ram, cpu cooler, cpu! Underkill GPU!
Intel Core i7 4770k - 2x Geforce GTX 780 - MSI Z87 MPower Max - Corsair H60 - 8GB Avexir Core Series MPower Yellow + 4gb no-brand DDR3 - Corsair Obsidian 750d - AData XPG SX900 256gb SSD - Seagate Barracuda 3TB (7200 RPM) - Hitachi 250GB 2.5in HDD (3200 RPM) - WD HDD 160GB extracted from iMac via black magic (no specified RPM) - ASUS VG248QE 144HZ 3d Vision Monitor - Logitech G602 - Ducky Shine 3 TKL - AKG 172 HD Headphones - Xperia z2 - Sony Noise canceling earphones -  Nikon D5200 With Bundled Lenses - Windows 7 Home Premium - Blue Snowball iCE - Acer Aspire X with a broken case, AMD A6, and Raijintek Aidos CPU heatsink
https://linustechtips.com/topic/112306-first-build/#findComment-1501611
i know but he wants to build a custom loop in future and this is his first pc he has build, now he didnt give a time scale so i dont know when he wants to make it but because its his first build i just dont recommend making a loop till he has more experience
Specs
https://linustechtips.com/topic/112306-first-build/#findComment-1501612
This is My first build i'm just a little late getting it posted on here, I was more or less looking for imput on what you all think of the build I checked Linus's build guides to get an idea of what i wanted to do.
https://linustechtips.com/topic/112306-first-build/#findComment-1501615
Ok, I understand. But maybe this topic is more suited for the New Build and Planning section.
As for my honest opinion:
I don't think it's worth to do a custom loop with a 8320 (if you are planning to do that).
Upgrade everything you can before making a custom loop.
And like other people said the 270x is slightly underpowered in this build, since you don't game that much that shouldn't really matter.
So my recommendation:
Upgrade to i7 and high end GPU before waterdcooling.
Feel free to disagree and good luck :)
THE signature
https://linustechtips.com/topic/112306-first-build/#findComment-1501645
I agree there i should have gotten a 280x when i had the chance and atleast i didn't get the 2133mhz ram i was looking at
Hey everyone has a learning curve, for your first build thats pretty solid :D
CPU: i7-4770k (LM modded) - MB: GA-Z87X-UD3H - RAM: HyperX, 16GB 1866MHz - GPU: Palit GTX 980Ti Super - Storage: 1TB HDD + 500GB/120GB SSD (850 Evo/840) - Monitor: Predator XB271HU - PSU: 700W BeQuiet 80+ Gold
https://linustechtips.com/topic/112306-first-build/#findComment-1501683
Before I go with a custom loop i'm going to change mobo and Graphics card i should have stated that when i built this i wasn't gaming on pc much but as i was not impressed with either the Xbox one or the Ps4 I decided I'm done with buying consoles and i play BF4 on my PC @ 50 fps on ultra @ 1080 no i do get a few time it dips to 30 fps for a few seconds also this is with the Mantle beta
https://linustechtips.com/topic/112306-first-build/#findComment-1501745
I already have it assembled i just wanted it checked out to see what mistakes i may have made and what you all think since I pretty much had no real idea which parts to pick Thank's to Linus's videos it sounds like i may not have messed up that badly and ya i was looking into a custom loop with the 8320 thank you for the imput but what amd cpu would you say was worth it since i wanted this to be an AMD build since i've never used an amd cpu i thought i'd give them a try and so far i'm happy with it
https://linustechtips.com/topic/112306-first-build/#findComment-1501754
Hmm, if you really want a custom loop with AMD, go ahead. I also had no complaints about my FX-8350, until I wanted to go small formfactor --> no good motherboards. So I sidegraded to the i5 4670k.
But the reality is, the i7 will simply perform better (in most applications), that's why I'd upgrade to i7. You could check out the FX-9590, but they're quite overpriced.
THE signature
https://linustechtips.com/topic/112306-first-build/#findComment-1501835
