No audio output is installed.
Shre96iyer
Hi guys,
I have a bit of a situation here my pc says audio output device not installed, I have tried most of the solution provided out there but no result, a little assistance is much appreciated.
Thanks & Regards,
I am going to assume you are talking about your onboard audio. Check device manager for any HW that has no drivers installed. If you dont even see anything without drivers check your bios to see if you somehow disabled your onboard audio. If not you probably have a dead sound card.
