Cooler dimensions help!!!
Solved by apebanan,
2 hours ago, lee32uk said:How do you figure that out ? It would fit but it would be touching the side panel if both measurements are accurate.
The chance of the measurements being wrong on this unknown brands info is very high, i personally would not risk it
HunterSVK ·
Posted in Troubleshooting1 -
Ozzi ·
Posted in Networking4 -
2
MadManMarsBar ·
Posted in Build Logs1 -
IAmAndre ·
Posted in New Builds and Planning7 -
4
3
Playgb2 ·
Posted in Troubleshooting2 -
3
2
play_circle_filled
Latest From ShortCircuit:
