Need help picking between these two monitors
I was looking at these two Samsung and AOC monitors and couldn't find any obvious differences between the two to help me pick. Any input would be appreciated :)
(Linus did a video on the AOC monitor but there seems to be no info anywhere on the samsung)
https://www.amazon.com/dp/B07R82333S/?coliid=ISMH520X77AMC&colid=26T8FBXMJ8MMZ&psc=1&ref_=lv_ov_lig_dp_it
https://www.amazon.com/dp/B07V39QHMY/?coliid=I2CBBT3LPLQG6H&colid=26T8FBXMJ8MMZ&psc=1&ref_=lv_ov_lig_dp_it
More information requested, like use scenario, what you're connecting it to, etc.
Based on monitor specs alone I'd go for the AOC because you already have a review available to you and the warranty plan seems pretty awesome.  I've worked for Samsung product support once upon a time (like a decade ago), sometimes we weren't allowed to be that nice.
I would say you should look at a curved TV/monitor in person before you buy one though.  Some people like them, some don't.
90% of the time its gonna be gaming. I dont think either of those monitors are offered somewhere near me where i can see them in person
It'd be nice if you could see the exact models in person, but my earlier comment was specifically referring to the differences between a curved panel vs. a flat panel.  Looking at TVs on display for example where they show off a Samsung curved panel TV would help you determine if you liked the curved panel.
I would not recommend either without 1st seeing a statistical thorough review.
I have only found 'overviews' of the specs with some subjective opinions. Nothing factual or statistical (like those from rtings.com or tftcentral.co.uk)
I'd suggest u look at the aforementioned review sites and see what catches ur eye their. I advise against buying a monitor based purely on specs and subjective overviews since they never tell u everything u need to know and are very misleading.*
*example: Specs never give u information on panel uniformity
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
Oh yea i could definitely do that, thanks
Linus did a vid on the AOC monitor but it sees that the samsung one is brand new or something cause there are absolutely no reviews of it
LTT do ....overviews. With 'some' technical testing like color gamut.
but they are far from thorough reviews. They lack a lot of the technical factual testing required for a full review. its ill advised to base purchasing decisions on 'overviews' like that.
No reviews being available isnt always an indication of it being brand new,  sometimes they are just not worth reviewing.
