Help with avoiding bottlenecking
Will it bottleneck a ~2080 level card? Oh yes, but mainly in newer titles, they just need more than 4 threads. Battlefiled V for example will happily eat up 10 threads. Rocket league on the other hand would probably happily run on a core 2 duo.
Like @Chiyawa said, if used market around you is good, get a 4th gen i7 and just OC the crap out of it (assuming cooling is good enough) The hyperthreading will really help out and probably give you another year or two breathing room before you have to do a full rebuild.
I'm in the UK and CeX (used hardware shop chain) has 4770k listed for £115($145 usd) so probably not too hard to find even cheaper looking at private sellers if you want to. Then sell your i5 and you'll probably get half the cost back anyway
