Hello,
I wanna buy a wireless headphone, I will use it mostly for gaming and listening to music, watching some videos and daily tasks like phone calls and etc. it should play mp3 and and be used wired as you don't want extra ping in games.It'd be good if it has a mic.
So, what do you suggest?
https://linustechtips.com/topic/1120728-wireless-headphone/
1 minute ago, Wictorian said:
Hello,
Probably these.
I got a ps5 and a pc pretty ballin
https://linustechtips.com/topic/1120728-wireless-headphone/#findComment-13022905
5 minutes ago, Wictorian said:
Can it play mp3 and used as wired?
Yes
3 minutes ago, Wictorian said:
And can i connect it also to my phone because it says it requires a wireless bluetooth connector
You can connect it via 3.5mm jack, but not wirelessly.
https://linustechtips.com/topic/1120728-wireless-headphone/#findComment-13022928
21 minutes ago, Wictorian said:
Well, is there one that I can connect to my phone wirelessly?
I think that if that is a dealbreaker for you, then buying a gaming headset and then buying some earbuds would be your best bet.
For a gaming headset, I’d go with these.
For earbuds I’d go with Bose Soundsports, or if you have an iPhone, I’d consider AirPods, depending on your budget.
https://linustechtips.com/topic/1120728-wireless-headphone/#findComment-13023062
Well yes then it is the best option, I don't have iPhone, can you please tell me the cheapest earbuds but they should have a good blurtooth quality because I got one for like 5 dollars and the connection wasn't so good and sometimes I wasn't able to hear because there was no sound.
https://linustechtips.com/topic/1120728-wireless-headphone/#findComment-13024397
Like I said before, Bose Soundsports are nice, but they’re around $120. I don’t know of very many cheap options in Turkey, so I can’t really help. I’d try looking at Amazon or something similar and just read some reviews before you buy.
https://linustechtips.com/topic/1120728-wireless-headphone/#findComment-13025468
