you can get genuine MX switches on aliexpress. shouldn't cost you more than a buck usually, but shipping might take a while.
alternatively you could buy a donor board somewhere secondhand and desolder the switch from there.
It uses scissor switches, it's not a mechanical keyboard.
Just now, Shrepto said:
Already gone that route, but they still haven't responded since Thursday.  Their phone line is only for technical help.
You could try calling them anyways, it's sort of technical help, if they can't help you they should connect you to those who can.
oh, sorry about that. that's a pretty misleading product name ?
i'm not sure about scissor switches. if it is a loose individual switch you might be able to fix it, tough if it has some sort of membrane you might be out of luck.
The switch broke part of its plastic piece.  It is removable, that much I know, but with it broken it doesn't hold down the lower section of the key cap.  I don't know much about scissor switches, and I'm not sure where I could go to buy one.
Logitech's customer service said that they don't have replacement key caps after I clarified with 'Gerald' it was the scissor switch and not the key cap.  So apparently, if this isn't warrantied you're basically fucked.
Which is going to really piss me off after hearing these raving reviews about Logitech's customer service being top notch.
  • 2 weeks later...
I believe I was able to find a direct replacement for this, which is apparently referred to as a 'hinge'.  Either way, glad I found it.  Crossing my fingers it works for the MX Keys, it looks like the exact same hinge.
http://www.machinaelectronics.com/store/keyboardkeys/5389
Cost me $7.50 for a single hinge, key cap, and rubber boot.  Only needed the hinge but can't find their number and didn't care to wait to order it last night.
  • 1 year later...
Hello there! Where you able to fix it? I seem to be in the same issue.
