Today I wanted to upgrade my rather old setup to something new, but now after assembling everything my PC won't boot.
Setup:
MSI X470 Gaming Pro
AMD Ryzen 3600
Asus Strix GTX970
Corsair Vengence LPX DDR4 2c8GB 3200mhz
I connected everything the way it should be, but it would not show any bios on boot, only the CPU EZ debug LED is on, I've tried plugging in only one monitor into the graphics card, I took out the CPU and put it back in, I pressed the clear CMOS button while the PC was off, it didnt change a thing, now I've only plugged my windows 10 SSD in but it still doesnt want to "start"
I'm out of ideas, could you guys help me?
(Sorry for my poor English, I'm from germany and it ain't my first language)
https://linustechtips.com/topic/1120194-problem-while-booting-upgraded-pc/
Does your mobo box say "MAX" on the box anywhere? That motherboard only supports 3000 series out of the box if it's marked with "MAX" on the box. If not, you need to update bios. The picture I attached shows the MAX marking. "X470 GAMING PRO 'MAX'"
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
  Hide contents
It does not say max on it, now a rather bland question, I do t know how to update the bios neither do I know where to get the update, never done that before. Very big thank you tho ♡
Do you have a second PC, or are you posting this from a phone? If you have a second PC and a USB stick it's very easy!
@Panikalarm02
Edited. Forgot to
Project Hot Box
Oppbevaring
@Panikalarm02
Edited. Forgot to
I've got 2 laptops here and if those wont work, I could still throw in the old board and CPU
@Panikalarm02 It looks like you might need to use a CPU that your mobo currently supports to update the BIOS, but might not. I'm not 100% sure. I've not dealt with that motherboard. I'm just going off what the manual and MSI say.
You'll need to download a bios that is at least new enough to support the 3000 series. "7B79v1A" or newer.
Put the downloaded file onto your USB stick.
Boot the CPU into BIOS.
Go to M-Flash in your BIOS and select the file on your USB stick.
Bios Link. https://www.msi.com/Motherboard/support/X470-GAMING-PRO
Instruction from the user manual. Looks like it should be Page 23 in the English part of the manual.
Project Hot Box
Oppbevaring
  Reveal hidden contents
I need a cpu that my board supports -.- I'm going to a PC shop tomorrow and ask if I could rent one (its currently 2:45 am here)
