Discord.js Issues
Solved by Jisagi,
I'm not sure why you put the eventloading inside an async block. Since it's the bot.on function inside that block which fails, it might be a good idea to make this block sync. Then you can also kick promisify. fs.readdir also has a sync version, so it would then look something like shown below. Worth trying I guess.
// Old (async () => { let events = await readdir("./main/events/"); events.forEach(file => { const name = file.slice(0, -3); const event = require(`./main/events/${file}`); //Stole this line as it was so much better than what I had: bot.on(name, event.bind(null, bot)); }); })(); // New const { readdirSync } = require('fs'); let events = readdirSync('./main/events/'); events.forEach(file => { const name = file.slice(0, -3); const event = require(`./main/events/${file}`); bot.on(name, event.bind(null, bot)); });
BTW, you have 2 message event handlers in line 85 and 114. You already use an eventloader structure, so why no moving it there as well?
