So hi guys basicly i am trying to setup nextcloud , thid works amazing but i have one problem i cant connect if i am in the same network.
I have a server running with ip 192.168.1.140
Apache is running on port 80 and 443 and is port forwarded in my router.
I have bought an hostname "example.com"
Example.com has an A record to my IP
When outside my home network i can connect to example.com but when inside my network i can not connect it just doenst work.
What can cause this?
https://linustechtips.com/topic/1119667-hostname-not-resolving-within-network/
It sounds like you're relying on the DNS relay of your router which most consumer ones use a really shitty implementation of bind which doesnt support NAT loopback.
The expensive fix? Get a better router
The technical fix? Setup your own DNS relay (e.g Raspberry Pi with Pi-Hole)
The easy fix? Add a static entry to the 'hosts' file on the machines you want to access via the domain name.
Edit: If DNS is on your router, you could also check for firmware updates to your router. If the router supports it you could also use a custom firmware like DD-WRT / OpenWRT / Tomato which do NAT hairpinning.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
4 minutes ago, Radium_Angel said:
firewall? DNS issues?
Firewall is allowed from anywhere on port 80/443
When on outside network like say my schools network i can connect to Example.com
but when i am home i can only connect with ip 192.168.1.140:443 but not example.com
It an ubiquiti security gateway.
So if you do an nslookup of your domain name, does it return a result with the A record you setup?
Do you just have a single network, or do you have VLAN's?
If just a single network, can you show your firewall/port forwarding configuration for the port 80/443 from your Unifi Controller?
Its a single network no VLANS
Ubiquiti:
Unreachable
22 minutes ago, JoranC123 said:
Ubiquiti:
And I assume on the Firewall tab, if you go to "LAN LOCAL" then you have no deny rules in there?
Not really seeing anything obvious...
You could try enabling all logging (Settings > Routing & Firewall > Firewall > Settings > Default Action Logging) - (Wait for it to finish Provisioning)
Try loading the site, then SSH (e.g with PuTTY) into your USG (user/password is in Settings > Site > Device Authentication) and run tail -f /var/log/messages
I dont hav any rules configured in LAN LOCAL
My pc is 192.168.1.34
This is the output:
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57964 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=57965 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57966 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57967 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57968 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57969 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57970 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57971 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57972 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57973 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57974 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57975 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57976 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57977 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57978 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57979 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57980 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=57981 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK PSH URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57982 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57983 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57984 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57985 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57986 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57987 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=57988 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57989 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57990 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57991 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57992 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57993 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57994 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57995 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57996 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57997 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57998 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=57999 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58000 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58001 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58002 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58003 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58004 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK PSH URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58005 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58006 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58007 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58008 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58009 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58010 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58011 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58012 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58013 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58014 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.74.54.38 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=57 ID=50841 DF PROTO=TCP SPT=45879 DPT=80 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58015 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58016 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58017 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58018 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58019 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58020 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58021 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58022 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58023 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58024 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58025 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58026 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58027 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58028 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58029 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58030 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58031 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58032 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58033 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58034 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58035 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58036 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58037 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58038 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58039 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58040 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58041 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58042 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:37:53 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.74.61.85 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=70 ID=4971 DF PROTO=TCP SPT=59273 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:37:54 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.255 LEN=291 TOS=0x00 PREC=0x00 TTL=128 ID=59861 PROTO=UDP SPT=54915 DPT=54915 LEN=271
Nov  2 13:37:54 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.75.188.84 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=72 ID=50845 DF PROTO=TCP SPT=54118 DPT=80 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:37:54 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:c8:db:26:05:54:68:08:00 SRC=192.168.1.126 DST=192.168.1.1 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=ICMP TYPE=8 CODE=0 ID=0 SEQ=0
Nov  2 13:37:55 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.255 LEN=291 TOS=0x00 PREC=0x00 TTL=128 ID=59862 PROTO=UDP SPT=54915 DPT=54915 LEN=271
Nov  2 13:37:55 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.52.44.244 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=80 ID=40245 DF PROTO=TCP SPT=47948 DPT=80 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:37:55 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.74.18.104 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=75 ID=11130 DF PROTO=TCP SPT=50872 DPT=80 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:37:55 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:21:5e:db:24:34:08:00 SRC=192.168.1.140 DST=192.168.1.255 LEN=49 TOS=0x00 PREC=0x00 TTL=64 ID=52044 DF PROTO=UDP SPT=33377 DPT=32414 LEN=29
Nov  2 13:37:55 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:21:5e:db:24:34:08:00 SRC=192.168.1.140 DST=192.168.1.255 LEN=49 TOS=0x00 PREC=0x00 TTL=64 ID=52045 DF PROTO=UDP SPT=32951 DPT=32412 LEN=29
Nov  2 13:37:56 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.255 LEN=291 TOS=0x00 PREC=0x00 TTL=128 ID=59863 PROTO=UDP SPT=54915 DPT=54915 LEN=271
Nov  2 13:37:56 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.74.63.105 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=76 ID=24612 DF PROTO=TCP SPT=49705 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:37:56 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.74.54.105 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=59 ID=30614 DF PROTO=TCP SPT=52202 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:37:57 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=58.180.101.13 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=52 ID=63761 DF PROTO=TCP SPT=46620 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:37:57 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.255 LEN=291 TOS=0x00 PREC=0x00 TTL=128 ID=59864 PROTO=UDP SPT=54915 DPT=54915 LEN=271
Nov  2 13:37:57 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.91.19.200 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=64 ID=25009 DF PROTO=TCP SPT=58361 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:37:58 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.255 LEN=291 TOS=0x00 PREC=0x00 TTL=128 ID=59865 PROTO=UDP SPT=54915 DPT=54915 LEN=271
Nov  2 13:37:58 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.75.188.84 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=54 ID=40906 DF PROTO=TCP SPT=32954 DPT=80 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:37:59 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.255 LEN=291 TOS=0x00 PREC=0x00 TTL=128 ID=59866 PROTO=UDP SPT=54915 DPT=54915 LEN=271
Nov  2 13:37:59 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.245.2.225 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=56 ID=30343 DF PROTO=TCP SPT=39913 DPT=80 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:37:59 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.75.188.84 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=70 ID=43556 DF PROTO=TCP SPT=63219 DPT=80 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:37:59 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.52.44.244 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=81 ID=19616 DF PROTO=TCP SPT=43045 DPT=80 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:37:59 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.52.44.244 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=54 ID=46568 DF PROTO=TCP SPT=41598 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:38:00 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.255 LEN=291 TOS=0x00 PREC=0x00 TTL=128 ID=59867 PROTO=UDP SPT=54915 DPT=54915 LEN=271
Nov  2 13:38:00 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=58.180.101.13 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=53 ID=49434 DF PROTO=TCP SPT=61455 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:38:00 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.74.61.85 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=55 ID=51519 DF PROTO=TCP SPT=42097 DPT=80 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:38:00 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:21:5e:db:24:34:08:00 SRC=192.168.1.140 DST=192.168.1.255 LEN=49 TOS=0x00 PREC=0x00 TTL=64 ID=54708 DF PROTO=UDP SPT=33377 DPT=32414 LEN=29
Nov  2 13:38:00 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:21:5e:db:24:34:08:00 SRC=192.168.1.140 DST=192.168.1.255 LEN=49 TOS=0x00 PREC=0x00 TTL=64 ID=54709 DF PROTO=UDP SPT=32951 DPT=32412 LEN=29
Nov  2 13:38:00 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.74.54.38 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=75 ID=37901 DF PROTO=TCP SPT=47588 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:38:01 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.255 LEN=291 TOS=0x00 PREC=0x00 TTL=128 ID=59868 PROTO=UDP SPT=54915 DPT=54915 LEN=271
Nov  2 13:38:01 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.74.54.38 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=62 ID=25171 DF PROTO=TCP SPT=60161 DPT=80 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:38:01 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.245.2.225 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=59 ID=23538 DF PROTO=TCP SPT=56738 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:38:01 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:b0:c5:54:25:ef:0d:08:00 SRC=192.168.1.46 DST=255.255.255.255 LEN=345 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=62976 DPT=62976 LEN=325
Nov  2 13:38:02 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.255 LEN=291 TOS=0x00 PREC=0x00 TTL=128 ID=59869 PROTO=UDP SPT=54915 DPT=54915 LEN=271
Nov  2 13:38:02 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.75.248.114 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=64 ID=3543 DF PROTO=TCP SPT=43635 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:38:02 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.74.54.8 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=75 ID=25496 DF PROTO=TCP SPT=43571 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:38:02 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.75.188.84 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=55 ID=64500 DF PROTO=TCP SPT=55282 DPT=80 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:38:03 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.255 LEN=291 TOS=0x00 PREC=0x00 TTL=128 ID=59870 PROTO=UDP SPT=54915 DPT=54915 LEN=271
Nov  2 13:38:03 Router kernel: [WAN_LOCAL-default-D]IN=eth0 OUT= MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=109.252.20.173 DST=192.168.0.134 LEN=134 TOS=0x00 PREC=0x00 TTL=51 ID=30250 DF PROTO=UDP SPT=4628 DPT=51413 LEN=114
Nov  2 13:38:03 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:00:21:5e:db:24:34:08:00 SRC=192.168.1.140 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=27077 DF PROTO=TCP SPT=8080 DPT=56117 WINDOW=0 RES=0x00 RST URGP=0
Nov  2 13:38:03 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:00:21:5e:db:24:34:08:00 SRC=192.168.1.140 DST=192.168.1.1 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=0 DF PROTO=TCP SPT=8080 DPT=56127 WINDOW=28960 RES=0x00 ACK SYN URGP=0
Nov  2 13:38:03 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:00:21:5e:db:24:34:08:00 SRC=192.168.1.140 DST=192.168.1.1 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=63784 DF PROTO=TCP SPT=8080 DPT=56127 WINDOW=235 RES=0x00 ACK URGP=0
Nov  2 13:38:03 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:00:21:5e:db:24:34:08:00 SRC=192.168.1.140 DST=192.168.1.1 LEN=69 TOS=0x00 PREC=0x00 TTL=63 ID=63785 DF PROTO=TCP SPT=8080 DPT=56127 WINDOW=235 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:03 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:00:21:5e:db:24:34:08:00 SRC=192.168.1.140 DST=192.168.1.1 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=63786 DF PROTO=TCP SPT=8080 DPT=56127 WINDOW=416 RES=0x00 ACK URGP=0
Nov  2 13:38:03 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:00:21:5e:db:24:34:08:00 SRC=192.168.1.140 DST=192.168.1.1 LEN=286 TOS=0x00 PREC=0x00 TTL=63 ID=63787 DF PROTO=TCP SPT=8080 DPT=56127 WINDOW=439 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:03 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.245.2.225 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=79 ID=6894 DF PROTO=TCP SPT=57814 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:38:04 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.255 LEN=291 TOS=0x00 PREC=0x00 TTL=128 ID=59871 PROTO=UDP SPT=54915 DPT=54915 LEN=271
Nov  2 13:38:04 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:20:df:b9:25:de:41:08:00 SRC=192.168.1.32 DST=192.168.1.1 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=ICMP TYPE=8 CODE=0 ID=495 SEQ=1
Nov  2 13:38:04 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.74.54.105 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=77 ID=43077 DF PROTO=TCP SPT=52934 DPT=80 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:38:05 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.255 LEN=291 TOS=0x00 PREC=0x00 TTL=128 ID=59872 PROTO=UDP SPT=54915 DPT=54915 LEN=271
Nov  2 13:38:05 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.74.63.105 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=76 ID=25958 DF PROTO=TCP SPT=40393 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:38:05 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.75.188.84 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=61 ID=18459 DF PROTO=TCP SPT=59000 DPT=80 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:38:05 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:20:df:b9:25:de:41:08:00 SRC=192.168.1.32 DST=192.168.1.1 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=ICMP TYPE=8 CODE=0 ID=495 SEQ=2
Nov  2 13:38:05 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:21:5e:db:24:34:08:00 SRC=192.168.1.140 DST=192.168.1.255 LEN=49 TOS=0x00 PREC=0x00 TTL=64 ID=54710 DF PROTO=UDP SPT=33377 DPT=32414 LEN=29
Nov  2 13:38:05 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:21:5e:db:24:34:08:00 SRC=192.168.1.140 DST=192.168.1.255 LEN=49 TOS=0x00 PREC=0x00 TTL=64 ID=58059 DF PROTO=UDP SPT=32951 DPT=32412 LEN=29
Nov  2 13:38:06 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.255 LEN=291 TOS=0x00 PREC=0x00 TTL=128 ID=59873 PROTO=UDP SPT=54915 DPT=54915 LEN=271
Nov  2 13:38:06 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.74.54.38 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=80 ID=33014 DF PROTO=TCP SPT=53653 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=104 TOS=0x00 PREC=0x00 TTL=128 ID=58043 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.255 LEN=291 TOS=0x00 PREC=0x00 TTL=128 ID=59874 PROTO=UDP SPT=54915 DPT=54915 LEN=271
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58044 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8206 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=104 TOS=0x00 PREC=0x00 TTL=128 ID=58045 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8206 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58046 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58047 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58048 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58049 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58050 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58051 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58052 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58053 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58054 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58055 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58056 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58057 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58058 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58059 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58060 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58061 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58062 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58063 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58064 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58065 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58066 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58067 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58068 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58069 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58070 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58071 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58072 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58073 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58074 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58075 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58076 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58077 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58078 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58079 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58080 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58081 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58082 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58083 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58084 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58085 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58086 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58087 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58088 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58089 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58090 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58091 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58092 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58093 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58094 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58095 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58096 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58097 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58098 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58099 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58100 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58101 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58102 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58103 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58104 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58105 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58106 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58107 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58108 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58109 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58110 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58111 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58112 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58113 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58114 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58115 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58116 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58117 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58118 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58119 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58120 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58121 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58122 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58123 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58124 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58125 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58126 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58127 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58128 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58129 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58130 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58131 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58132 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58133 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58134 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58135 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58136 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58137 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58138 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58139 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58140 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58141 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58142 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58143 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58144 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58145 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58146 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58147 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58148 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58149 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58150 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58151 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58152 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58153 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58154 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58155 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58156 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58157 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58158 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58159 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58160 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58161 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58162 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58163 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58164 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58165 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58166 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58167 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58168 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58169 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58170 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58171 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58172 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58173 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58174 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58175 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58176 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58177 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58178 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58179 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58180 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58181 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58182 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58183 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58184 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58185 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58186 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58187 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58188 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58189 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58190 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58191 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58192 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58193 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58194 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58195 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58196 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58197 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58198 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58199 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58200 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58201 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58202 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58203 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58204 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58205 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58206 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58207 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58208 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58209 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58210 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58211 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58212 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58213 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58214 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58215 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58216 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58217 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58218 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58219 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58220 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58221 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58222 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58223 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58224 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58225 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58226 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58227 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58228 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58229 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58230 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58231 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58232 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58233 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58234 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58235 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58236 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58237 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58238 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58239 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58240 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58241 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58242 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58243 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58244 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58245 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58246 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58247 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58248 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58249 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58250 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58251 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58252 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58253 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58254 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58255 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58256 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58257 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58258 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58259 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58260 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58261 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58262 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58263 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58264 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58265 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58266 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58267 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58268 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58269 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58270 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58271 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58272 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58273 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58274 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58275 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58276 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58277 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58278 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58279 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58280 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58281 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58282 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58283 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58284 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58285 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58286 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58287 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58288 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58289 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58290 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58291 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58292 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58293 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58294 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58295 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58296 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58297 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58298 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58299 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58300 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58301 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58302 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58303 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58304 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58305 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58306 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58307 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58308 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58309 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58310 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58311 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58312 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58313 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58314 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58315 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58316 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58317 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58318 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58319 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58320 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58321 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58322 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58323 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58324 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58325 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58326 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58327 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58328 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58329 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58330 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58331 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58332 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58333 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58334 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58335 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58336 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58337 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58338 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58339 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58340 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58341 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58342 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58343 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58344 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58345 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58346 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58347 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58348 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58349 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58350 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58351 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58352 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58353 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58354 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58355 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58356 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58357 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58358 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58359 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58360 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58361 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58362 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58363 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58364 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58365 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58366 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58367 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58368 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58369 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58370 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58371 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58372 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58373 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58374 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58375 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58376 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58377 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58378 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58379 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58380 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58381 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58382 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58383 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58384 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58385 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58386 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58387 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58388 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58389 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58390 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58391 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58392 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58393 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58394 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58395 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58396 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58397 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58398 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58399 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58400 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58401 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58402 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58403 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58404 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58405 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58406 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58407 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58408 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58409 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58410 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58411 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58412 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58413 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58414 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58415 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58416 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58417 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58418 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58419 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58420 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58421 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58422 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58423 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58424 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58425 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58426 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58427 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58428 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=200 TOS=0x00 PREC=0x00 TTL=128 ID=58429 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8207 RES=0x00 ACK PSH URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58430 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58431 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Nov  2 13:38:07 Router kernel: [LAN_LOCAL-default-A]IN=eth1 OUT= MAC=fc:ec:da:47:42:2e:f0:79:59:60:7a:e2:08:00 SRC=192.168.1.34 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=58432 DF PROTO=TCP SPT=58611 DPT=22 WINDOW=8212 RES=0x00 ACK URGP=0
Interesting. So checking that output we can see the external requests
e.g can see from this 47.52.* address to 192.168.1.140 on 443/TCP has been allowed.
But can't actually see any of the local attempts which I assume would be in LAN_LOCAL-default-A firewall rules.
	Line 102: Nov  2 13:37:59 Router kernel: [WAN_IN-3004-A]IN=eth0 OUT=eth1 MAC=fc:ec:da:47:42:2d:34:2c:c4:a8:bf:0c:08:00 SRC=47.52.44.244 DST=192.168.1.140 LEN=44 TOS=0x08 PREC=0x20 TTL=54 ID=46568 DF PROTO=TCP SPT=41598 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0
So just to confirm
- You dont have any sort of VPN enabled on your PC?
- This is happening from more devices, e.g your Smartphone or another PC?
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
So just to confirm
This is happening on all devices within network the weird thing is plex does work.
i adjusted my dns to 1.1.1.1 tho
The DNS shouldn't be the issue, especially since Plex is working.
I assume that http://192.168.1.140 works as well? (assuming you use VirtualHosts it should go to the default Apache landing page)
On that machine (192.168.1.140) what OS is it running? Have you checked the firewall on the machine?
and you haven't set up any weird advanced firewall rules?
just something simple like sudo ufw allow http(s)?
im at a loss as to what else the problem could be to why you only cant access those ports internally when its all forwarded fine...
1 hour ago, Denned said:
Do you have any local dns configured? If anything you could just edit the host file on your machine
i need to edit this on an android too...
i did ufw allow 80
and ufw allow 443
If you're using DHCP from your USG, then you should be able to just set static dhcp with a hostname for your server.
https://help.ubnt.com/hc/en-us/articles/360023759313-UniFi-USG-How-to-Set-a-Static-IP-Reservation-for-a-Client-UniFi-Device
It is a static ip already...
Yea, just realized the USG wont resolve hostnames that way.
You should be able to ssh into your usg and edit the host file under /etc/hosts
its not a hostname, its a domain name
but yeah i'd just add a static entry to your hosts file on the USG. Only thing is it might get cleared on firmware updates so you may need to reapply it if that happens.
just ssh into the USG and run
set system static-host-mapping host-name <domain name> inet 192.168.1.140
If you have 1.1.1.1 manually set on your PC as the DNS, then you need to edit your local hosts file C:\Windows\System32\drivers\etc\hosts
