Some days ago my PC would go on Bsod with the error DRIVER IRQL NOT LESS OR EQUAL casued by nvlddmkm.sys. I Uninstalled and reinstalled the Driver  because my Pc would load like the image. Doing so the problem was solved, or so i thought. Today my Desktop is always like this. Now, unfortunatelly i don't have a second GPU to test if it's my GPU or the PC. What do you think? Is the GPU dying slowly or is my PC? Right now i'm with the iGPU and the PC works just fine.
Thanks in advance.
GPU - Nvidia GTX 770
CPU - i7-3770K
https://linustechtips.com/topic/1119520-gpu-problem-or/
Thanks in advance.
CPU - i7-3770K
Have you used DDU to remove and reinstall the driver?
https://linustechtips.com/topic/1119520-gpu-problem-or/#findComment-13013420
1 minute ago, LUCRUS said:
So..should i just re-install the drivers and use DDU or use DDU
https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Download and install DDU.
Boot into safe mode.
Run DDU so it reboots after removing the driver.
Download the latest driver for the GPU and install.
If you still have the same issues after that then it's time to look at either Windows or hardware as the possible problem.
https://linustechtips.com/topic/1119520-gpu-problem-or/#findComment-13013445
Ok thanks a lot !
https://linustechtips.com/topic/1119520-gpu-problem-or/#findComment-13013446
Try testing the GPU with GPUPI 3.3.3,
Tell us if you get any errors while testing.
GPUPI 3.3.3 download page:
https://www.overclockers.at/news/gpupi-international-support-thread
Press Calculate then OK to start.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1119520-gpu-problem-or/#findComment-13013462
Still having the same issue, don't know where to look now...
https://linustechtips.com/topic/1119520-gpu-problem-or/#findComment-13013531
