Wireless headset
Solved by Streetguru,
2 hours ago, KingBlue72 said:I had like 2-3 Siberia 200's breakdown within 18 months
I think you may just have really bad luck, my sibera 200s haven't had any issues. Dunno how long I've had them.
Corsair has some cheaper wireless headphones, but their microphone was really bad.
Would probably stick to logitech or HyperX maybe otherwise, but the Arctis 7s should be fine.
