Use. Common. Sense. And. Or. Reason.
If all else fails, Google it
god's love ,Exodus 31:15 , Deuteronomy 17:2-7 , Deuteronomy 13:13-19 , Leviticus 24:16 , Leviticus 20:9, Leviticus 20:10 , Leviticus 20:13 , Deuteronomy 21:18-21 , Matthew 18: 7-9 , 1 Corinthians 14:34-35 , 1 Timothy 2:11-12 , Leviticus 25:44, Exodus 21:20 , Titus 2:9 , Isaiah 13:15/16/18 , Hosea 13:16 , Numbers 31:17-18
https://linustechtips.com/topic/111776-science-homework-help/#findComment-1494412
What causes the moon phases? I keep getting different answers from everywhere.
Edit: The only problem is is that I don't know how to word the answer. Type the answer as if someone asked you.
googles your best friend
Specs
https://linustechtips.com/topic/111776-science-homework-help/#findComment-1494422
So, the moon's phases are not caused by the shadow of the Earth falling on the moon. In fact the shadow of the Earth falls on the moon only twice a year, when there are lunar eclipses.
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/111776-science-homework-help/#findComment-1494433
The phases of the moon are not caused by the earth's shadow, they are caused on the positioning of you relative to the moon.
Basically, only one half of the moon is ever lit. The other half is always dark. We see different phases because of where the moon is located relative to us, as shown by my bad diagram. If you have any more questions, shoot :)
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/111776-science-homework-help/#findComment-1494488
