I got a new laptop that works great while plugged in, but when I unplug it, the performance tanks. I have set the power plan to high performance just like it would be when plugged in. In League of Legends, I go from 250-300 fps while plugged in to sometimes less than 100 when on battery. My specs are a 1660ti and 9750h in a gigbayte aero 15. Is there a setting that I am missing. I tried setting power management mode to prefer maximum performance which helped slightly, but still not enough to make the performance up to what I would expect
https://linustechtips.com/topic/1117624-get-full-performance-while-on-battery/
The thing is that manufacturers use small batteries that are not enough to power the laptop,
so they automatically downclock the CPU and GPU when on battery power.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
