Hello everyone,
I've made some upgrades to my system that I got from a site that is similar to iBuyPower, CyberPowerPC. It was not a pre-built, I used their configurator about 2 years ago during the worst possible time to build one (Dec. 2017) but I needed a new PC quickly as my old one "passed away" (insanely slow but that one was a pre-built that I got for cheap). The only upgrade I've done was swap out the MSI AERO ITX GTX1050, the 2x4GB Samsung value RAM and install a 500GB SSD as my boot drive and use my pre-existing 1TB Seagate Barracuda as a pure storage drive.
Long story short ever since I installed my new GPU and SSD (Sapphire RX 580 8GB, 500GB 970 EVO Plus) I have experienced very random freezes. Sometimes the freeze is barely noticeable as I can still move my cursor (the screen itself is frozen though), on other occasions everything freezes and I can't move the cursor. Then there are the very rare occasions where my screen just turns black (because of the freeze) and ultimately turns off because it doesn't detect a signal anymore. Another thing that has happened was that my PC bluescreened on me but this has only happened 1 or 2 times. I've look for advice pretty much everywhere but nothing has really proven beneficial.
I've checked that everything is plugged in correctly, even though it is near impossible for something to be loose. I've even went back to base clock on my GPU (OC'd it to 1450 on the core clock), I've completely wiped both my storage devices and did a full, clean install of windows on my SSD, reinstalled all drivers and everything else but... nothing. Everything is still the same I still get the random freezes and it seems like my screen turning off has become a bit "more" present as it happened to me 2 times in the last 2 weeks. This problem I'm having happens everywhere. It happens while just being idle and in some rare cases my monitor flickers, goes black for about 2 second goes back to the regular screen only to to black for 2 seconds again.
I didn't have any problems with the pc up until a month after I installed everything. I also noticed some coil whine while playing apex but that's random as well, sometimes it happens, sometimes it doesn't. When it happens, it only does so while playing Apex. I play/do everything on 1080p@60.
PC specs are as follows:
  • i5-7500 CPU
  • Sapphire Radeon RX580 8GB (latest GPU drivers)
  • 16 GB (2x8) Corsair Vengeance RGB 3000Mhz CL15 RAM
  • ASUS Prime Z270-K Motherboard (latest bios)
  • Samsung EVO 970 Pus (latest firmware and nvme drivers)
  • Seagate Barracuda 1TB HDD 7200rpm
  • Corsair TX550M PSU
Current rig
CPU: AMD Ryzen 7 3700X  | Cooling: Wraith Prism stock cooler for now, NZXT Kraken X62 soon | MOBO: MSI B450 Tomahawk Max | RAM: 16GB DDR4 3000MhzCL16 g.skill Trident Z Neo |
GPU: MSI RTX 2070 Super Gaming X | PSU: Corsair RM650(2019)   Boot:  500GB Samsung 970 EVO Plus NVMe SSD  | Storage: 1x 1TB WD Blue (WD10EZEX) HDD | Case: Cooler Master MasterBox NR600 w/o ODD | Display: Acer Nitro XV2 XV272UP 1440p 144Hz | OS: Windows 10 Pro.
Old rig
CPU: Intel Core i5 7500  | Cooling: be quiet! Pure Rock | MOBO: ASUS Prime Z270-K | RAM: 16GB DDR4 3000mhzCL15 Corsair Vengeance RGB with heatcage on top (predecessor of RGB Pro ram) | GPU: AMD Sapphire Pulse RX580 8GB | PSU: Corsair TXM550 80+ Gold   Boot:  500GB Samsung 970 EVO Plus NVMe SSD  | HDD: 1TB 7200 RPM Seagate Barracuda  | Case: Cooltek TG-01 | Display: ASUS VX238H | OS: Windows 10 Pro.
https://linustechtips.com/topic/1117243-pc-is-randomly-freezing/
