I have a A320M asrock board and a Ryzen 3 1200. I'm wanting to upgrade my CPU but not sure on the best solution. I just want to be able to continue gaming at midrange, make sure it's not gonna have issues with the swap and that's really it. I have a 1050ti currently and I have not came across a game I have not been able to play yet.  But I would like a little better performance. Any advice/ help is greatly appreciated.
https://linustechtips.com/topic/1117109-help-please/
depend on your budget, 1700, 2600 & 3600 are great options
remember to check cpu capability for your mobo and bios update
https://linustechtips.com/topic/1117109-help-please/#findComment-12994783
whats your budget and what are you looking to upgrade?
My Rig / Buildlogs:  ❄️ SNOWFLAKE ❄️ FROSTBITE ❄️
CPU: Ryzen 5 3600   Cooler: Corsair H115i Platinum   RAM: Corsair Vengence RGB Pro 16GB @3200   Mobo: Asus Prime X470 Pro
Graphics Card: Gigabyte Aorus 2080super Waterforce    Case: Corsair 500D   PSU: Corsair HX850i
Storage: 500GB Crucial P1 NVMe SSD, 1TB Crucial P1 NVMe SSD, 2x 1TB SATA SSD
Displays: AOC CQ32G1 32" 2560x1440, Acer XB280HK 28.0" 3840x2160 60 Hz, Medion MD20850 24" 2560x1440
https://linustechtips.com/topic/1117109-help-please/#findComment-12994786
3 minutes ago, MangoMyCactus said:
So right now I'd like to keep under 500 total
i looked "A320M" up on the asrock page and it seemes to support ryzen 3000 series cpus (probably with a bios update).
please be sure to check again for yourself as i am not 100% sure i got the right board.
i'd strongly advise against anything highter than a 3600 as i do not know how the board would handly any of the "larger" cpus.
that would be about 200$
if youll like a new mobo too you'll be looking at 300-350 total.
https://linustechtips.com/topic/1117109-help-please/#findComment-12994809
11 minutes ago, GalacticRuler said:
Is your CPU actively bottlenecking your system, or do you just want an upgrade for the sake of it? If it's the latter, I'd personally hold off until Black Friday when the killer deals come
Ok I'm not bottle necking currently. That's actually a great idea. I do not know why I did not think about that. I could buy more upgrades then. Maybe I'll get some more cooling fans as well. When running games my cpu sometimes hits up to 104 Farenheit.
https://linustechtips.com/topic/1117109-help-please/#findComment-12994841
That's an INSANELY cool CPU. There's no reason for you to get more fans since you'd only experience diminishing return and only more noise.
https://linustechtips.com/topic/1117109-help-please/#findComment-12994849
